Harley Pulley Brake Disc Spacer Steel 1/4 Thickness - V-Twin 19-0413 - Big Twin 0+
Steel 1/4 inch thick pulley and rotor spacer provides offset when required with a 7/16 inch bolt hole. The spacer measures 2-1/16 inch inner diameter with a 4-5/16 inch outer diameter. For spacing out rear sprocket rotor or pulley. The 2-1/16 inch inner diameter fits 1980-1999 FX-FL-XL hubs. Universal fit for most Harley applications.
- Inner Diameter: 2-1/16 inches
- Outer Diameter: 4-5/16 inches
- Thickness: 1/4 inches
