Harley Big Twin Inner Primary Cover and Oil Tank Mount Kit Parkerized - V-Twin 9601-10 - OEM 60642-36
Parkerized mount kit includes 2 hex screws springs cotter pins and washer. Attaches the inner primary to the oil tank and chain guard on top and to the frame tab. Rear chain guard stud attached to fender mount tab by 1/4 inch-24 hex nut not indlued. *NOTE: Oil tank inner primary and chain guard order for 1936-1952 EL and 1941-1957 FL models. Oil tank tab is between inner primary tab and chain guard. Use correct bolt and spring. Fits 1936-1964 Harley Flathead, Knucklehead, and Panhead models.
OEM #: 60642-36, 3814-36
| 1936-1940 | EL |
| 1941-1964 | FL |
| 1937-1948 | UL |
