Replica Clutch Plate Set - V-Twin 49-1160
Replica clutch plate set includes 1 clutch hub friction disc 1 fiber outer friction disc 2 lined clutch friction discs 2 steel drive discs and 1 spring steel drive disc.
Accurate OEM replica exact and ready to install! This clutch set fits the 1936-40 UL and EL narrow style 4 stud clutch hub assembly. Order backing plate rivets separately. *NOTE: Make sure flare fits over tapered fitting.
| 1936-1940 | EL |
| 1936-1940 | UL |
