36 Tooth Clutch Drum Assembly - V-Twin 18-0161 - OEM 37707-98A - Big Twin 1998-2006
SKU 18-0161
$339.99
$339.99
$339.99
$339.99
$339.99
$339.99
OEM #: 37707-98A
Clutch drum with bearing snap ring and 102 tooth starter ring gear installed. Clutch drum is 36 tooth.
*NOTE: To use on 1998-2001 Touring models with EFI will require the front engine sprocket to be changed to a 25 tooth type.
- Required to use with Compensator Engine Sprocket 25 Tooth for 1998-2001 Touring models with EFI.
| 1998-2006 | FLST |
| 1998-2005 | FLT |
| 1998-2005 | FXD |
| 1998-2006 | FXST |
