Harley Softail Adjustable Center Stand 1992-2007 FXST/FLST - V-Twin 16-1521 - OEM 98955-07 - Big Twin 1992-2007
SKU 16-1521
$259.99
2599 ENTRIES 🎟️
$259.99 - $259.99
$259.99
2599 ENTRIES 🎟️
Center stand that lifts the rear wheel for display or service — not a ride-off stand — a direct replacement for a worn or missing stock part. Fits 1992-2007 Harley Softail models.
OEM #: 98955-07
The chrome center stand bolts directly to the FXST and FLST model frame. It lifts the bike upright and stands by activating the lever on the left side. In this position the bike looks great for display or servicing.
Must order required hardware separately. **NOTE: Not for use as ride off stand. Does not fit FLSTS and FLSTSC. Does not work with air ride.
  • Mounting Width: 12-5/16 inches
  • Maximum Height: 7-1/8 inches
  • Lowest Height: 6-3/8 inches
  • 1992-1999 models require the left side boss to be drilled and tapped with a 3/8-16 tap.
  • Required to use with OEM #4713W - 3/8inch-16 x 3/4inch Hex Head Bolt.
  • Required to use with OEM #4716W - 3/8inch-16 x 1-1/4inch Hex Head Bolt.
  • Required to use with OEM #6874 - Washers.
1992-2007 FLST
1992-2007 FXST
