Weld-On Frame Hardtail - V-Twin 51-0920
SKU 51-0920
$339.99
$339.99 - $339.99
$339.99
Weld on hardtail fits stock frames is drum brake style and accepts chain drive.
DIY hardtailing is easy to install as the alignment is accomplished in the mount design provided. Welding should be performed by a skilled welding technician. Weld on unit should be aligned for chain clearance prior to final welding. The distance between the inside to inside of the axle plates is 9-1/8 inch. The axle slots are 7/8 inch on both sides. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • The width of the tail section should be exactly 9-1/8inch. Due to the welding process this may vary slightly & builder will need to modify accordingly.
