FXD Weld-On Frame Hardtail Raw - V-Twin 51-0786 - Evolution Dyna 1990-1998
SKU 51-0786
$369.99
3699 ENTRIES 🎟️
$369.99 - $369.99
$369.99
3699 ENTRIES 🎟️
FXD raw weld on hardtail is easy to install as the alignment is accomplished in the mount design provided.
Raw weld on hardtail uses a 14-1/2 inch rear axle a chrome rear caliper kit and a battery box is recommended when building this hardtail. Welding should be performed by a skilled welder technician. Custom application on 1991-1998 FXD and FXDWG models. Tubing outer diameter is 1-1/4 inch. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Between Axle Plates: 11-3/8 inches
  • Suggested to use with rear axle
  • Suggested to use with rear caliper kit
  • Check fitment before installation and welding.
1990-1998 FXD
1990-1998 FXDWG
