Harley Big Twin Replica Swingarm Frame - V-Twin 51-1006
Replica swingarm frame is our authentic reproduction of FLH style to accept a Panhead or Shovelhead engine 4-speed transmission seat post and accepts a round or square swingarm. All components are pressed and formed as stock. Frame details include forged parts as original in neck motor mounts front transmission mount plate top seat post yoke strut swingarm pivot mount and footboard mounts as required. Accepts a 12-volt electric start battery box. Fork neck without key lock has blank number boss on right side and will accept lock assembly. Frame will accept round 1958-1972 drum brake or square 1973-1985 swingarm. Order shock studs separately recommend using 12 or 13-1/2 inch shocks. Frame includes swingarm pin and oil tank bracket. Rear drum brake models use 13-1/2 inch shocks and rear disc brake models use 12 inch shocks. *NOTE: There are no serial numbers stamped on the replica frame. V-Twin MFG supplys a Bill of Sale only. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. **NOTE: Seat post may require further reaming for proper fit. For this reason frames will not be accepted for return (RGA). Fits 1965-1984 Harley Big Twin, Touring, Panhead, and Shovelhead models.
- *NOTE: The size of the blank number pad on the right side of the neck measures 3/4inch x 3inch.
| 1965-1984 | FL |
| 1965-1984 | FLH |
