Replica Knucklehead Frame - V-Twin 51-1941 - OEM 47003-41
OEM #: 47003-41, 2802-41
Knucklehead rigid frame is an authentic reproduction of the factory style frame.
Includes seat post assembly transmission mount plate and rear axle kit installed. The 29° neck angle will accept inline spring forks. This frame measures 13-11/16 inch from the rear motor mount following the seat post and straight up to the backbone. Features exact replica inchsaddles inch brazed at each end for read render crossbar support. Frame requires purchase of clamp on coil bracket kit. **NOTE: Seat post and cross shaft bushings may require further reaming for proper fit. For this reason frames will not be accepted for return (RGA). *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. *NOTE: There are no serial numbers stamped on the replica frame. V-Twin MFG supplys a Bill of Sale only referencing the part number.
| 1941-1946 | EL |
| 1941-1946 | FL |
| 1941-1946 | U |
