Factory Sample Front Engine Bar with Footpeg Pads Black - V-Twin 51-2219 - OEM 49140-05 - Twin Cam Softail 2000-2017
SKU 51-2219
$129.99
$129.99 - $129.99
$129.99
OEM #: 49140-05
Engine bar features a gloss black finish and integrated rubber pads for foot rests.
Hardware is not included. The engine bar has a diameter of 1-5/16 inch. **WARNING: This engine/frame bar may provide limited leg and cosmetic vehicle protection under unique circumstances (fall over while stopped very low speed slide). They are not made nor intended to provide protection from bodily injury in a collision with an automobile or any other object. *NOTE: Requires seperate purchase of mounting hardware which includes (2) 3/8 inch-16 x 1-1/4 inch bolts (4) 4/8 inch washers (2) 3/8 inch-16 nyloc nuts (1) 5/16 inch-18 x 7/8 inch bolt (1) 5/16 inch washer and (1) 5/16 inch-18 nyloc lock. Factory sample cover are brand new pre-production parts but have imperfections in the finished surface. Check threaded and bearing holes for excess plating before installation. There are no physical defects such as cracks or holes there will be cosmetic imperfections only. Sample parts may show marks from installation test and fitment.
  • *NOTE: UPS may consider this part as packaged inchoversizeinch for shipment as compared to the actual weight which will result in higher shipping costs.
2000-2017 FLST
