Factory Sample Chrome Front Engine Bar with Footpeg Pads - V-Twin 51-2220 - OEM 49155-09B
OEM #: 49155-09B
Engine bar features integrated rubber pads for foot rests with a chrome finish.
Includes mounting hardware. *NOTE: Does not fit models equipped with fairing lowers. *WARNING: This engine/frame bar may provide limited leg and cosmetic vehicle protection under unique circumstances (fall over while stopped very low speed slide). They are not made nor intended to provide protection from bodily injury in a collision with an automobile or any other object. Do not use engine guard footpegs or highway pegs under normal stop and go operating conditions. Doing so could result in death or serious injury. Factory sample cover are brand new pre-production parts but have imperfections in the finished surface. Check threaded and bearing holes for excess plating before installation. There are no physical defects such as cracks or holes there will be cosmetic imperfections only. Sample parts may show marks from installation test and fitment.
- Required to use with OEM #45700054 Bracket for 2015-up FLRTmodels.
- Required to use with OEM #83865-09 Bracket for 2010-2011 FLHXXX models
- *Note: UPS may consider this part as packaged inchoversizeinch for shipment as compared to the actual weight which will result in higher shipping costs.
