Harley Big Twin Frame and Fork Kit - V-Twin 55-0000
SKU 55-0000
Original price $3,879.99 - Original price $3,879.99
$3,879.99
38799 ENTRIES 🎟️
$3,879.99 - $3,879.99
$3,879.99
38799 ENTRIES 🎟️
Frame and fork kit includes replica wishbone frame kit and black 28 inch offset fork assembly. Kit includes wish bone 30° frame rear axle assembly transmission mount plate seat post assembly and brake cross shaft with bushings installed. Frame will accept Panhead or Shovelhead engine with 4-speed transmission also accepts Knuckle or Flathead engines with use of a 3/8 inch front engine mount spacer. Features seat post axle transmission plate mechanical brake cross shaft bushings tool box mount and grease fittings already installed. Forged parts include: Neck front and rear engine mounts side car mounts top seat post yoke footboard tabs and rear axle plates. Neck will accept key lock. Must order lower tank frame mount separately. *NOTE: Seat post and cross shaft bushings may require further reaming for proper fit. Fits 1946-1948 Harley Flathead, Knucklehead, and Panhead models.
  • Suggested to use with Lower Tank Frame Mount with Cross Plate.
  • *NOTE: There are no serial numbers stamped on the replica frame. V-Twin supplys a Bill of Sale only referencing the part number.
  • *NOTE: UPS may consider this part as packages inchoversizeinch for shipment as compared to the actual weight which will result in higher shipping costs.
  • *NOTE: Must fabricate a strap bracket flat or offset as required.
1946-1948 FL
1946-1948 UL
