Harley Shovelhead Rear 2 Piston Caliper with Bracket - Belt Drive LTD. GMA-100
Caliper mounting bracket for a clean, correct-fit brake setup. Fits 1973-1980 Harley Shovelhead models.
Belt Drive LTD. #: GMA-100
GMA billet anodized aluminum brake caliper features dual pistons internally connected and the bracket features a natural finish.
Spacers and hardware are included for installation. Use 5/8 inch bore master cylinder and a 10 inch brake disc. Measures 4-1/2 inch from the axle hole to the bottom mount hole and 3-5/8 inch from the axle hole to the caliper mount holes. Hoses and brake discs are not included.
- Spacer O.D.: 1-1/2 inches
- Spacer I.D.: 3/4 inches
- Spacer Thickness: 5/8 inches
| 1973-1980 | FL |
| 1973-1980 | FX |
