43 Stainless Steel Throttle and Idle Cable Set Clear Coat - V-Twin 36-0826 - OEM 56616-03 - Twin Cam Touring 2002-2007
SKU 36-0826
$69.99
$69.99 - $69.99
$69.99
OEM #: 56616-03
Throttle and idle set in braided stainless steel with a clear coat is stock length. The casing length is 43 inch for the idle cable and 39-1/2 inch for the throttle cable.
Stainless steel braided with a clear coat throttle and idle cable set includes switch control and a 90° elbow fitting with PVC coating. The stainless steel braid is tightly woven for a bright quality consistent finish. The clear coat is UV resistant heat bonded non yellowing grade for a long service life.
  • Travel Length: 4-3/4 inches
2002-2007 FLH
2002-2007 FLHRCI
2002-2007 FLHRI
