46 Stainless Steel Throttle and Idle Cable Set - V-Twin 36-0825 - OEM 56457-00A - Big Twin 1996-2001
OEM #: 56457-00A
Throttle and idle set in braided stainless steel with a clear coat is stock length. Casing length is 46 inch. The overall length of the throttle cable is 50.25 inch. Overall length of the idle cable is 50.75 inch.
Includes switch for cruise control fitting. Stainless steel braided with a clear coat throttle and idle cable set includes switch control and 90° fittings with PVC coating. The stainless steel braid is tightly woven for a bright quality consistent finish. The clear coat is UV resistant heat bonded non-yellowing grade for a long service life. These cables have a casing length of 46 inch.
- Length: 46.25 inches
| 1996-2001 | FLHTCUI |
| 1998-2001 | FLT |
| 1996 | FLTCUI |
