33.66 Stainless Steel Throttle and Idle Cable Set - V-Twin 36-0827 - OEM 56564-02 - Evolution Sportster 1999+
OEM #: 56564-02
Throttle and idle set in braided stainless steel with clear coat is stock length. Casing lenggth is 33.66 inch.
Stainless steel braided with a clear coat throttle and idle cable set includes a 45° elbow fitting. The stainless steel braid is tightly woven for a bright quality consistent finish. The clear coat is UV resistant heat bonded non-yellowing grade for a long service life. Cables have a casing length of 33.66 inch.
- Travel Measurement: 5 inches
| 1999-UP | XL |
