York Clutch Cable Adjuster - V-Twin 36-2200 - Big Twin 22-2023
SKU 36-2200
$54.99
$54.99
$54.99
$54.99
$54.99
$54.99
York clutch cable adjuster is for upgrading original adjuster on cable operated clutch models. Cable inner diameter is 12.6mm.
The upper cable holder has a 12.6mm inner diameter for cable to sit in. Replaces the stock plastic cable adjuster.
- Inner diameter: 12.6mm
- ° Converts the factory upper clutch cable adjuster to a screw type adjuster while reinforcing the cable
- ° For repair part for broken factory cable adjusters
- ° Works with stock cables Barnett or V-Twin cables
- ° 1/2-20 threaded split adjuster
| 2022-2023 | FLDE |
| 2022-2023 | FLFB |
| 22-2023 | FLHC |
| 2022-2023 | FLHR |
| 2022-2023 | FLHT |
| 2022-2023 | FLHTCU |
| 2022-2023 | FLHTK |
| 2022-2023 | FLHX |
| 2022-2023 | FLS |
| 2022-2023 | FLSB |
| 2022-2023 | FLSL |
| 2022-2023 | FLST |
| 2022 | FLSTN |
| 2022-2023 | FLTR |
| 2022-2023 | FXBB |
| 2022-2023 | FXBR |
| 2022-2023 | FXCW |
| 2022-2023 | FXFB |
| 2022-2023 | FXLR |
| 2022-2023 | FXS |
| 2022-2023 | FXSB |
| 2022-2023 | FXST |
