72.81 Braided Stainless Steel Clutch Cable - V-Twin 36-0867 - OEM 38789-06A - Twin Cam 2007-2017
OEM #: 38789-06A
Clutch cable in braided stainless steel with clear coat is +6 inch over stock length. Casing length is 72.81 inch.
Stainless steel braided with a clear coat clutch cable has a PVC sleeve. The braid is tightly woven for a bright quality consistent finish. The clear coat is UV resistant heat bonded non yellowing grade for a long service life.
| 2007-2017 | FLST |
| 2007-2017 | FLT |
| 2007-2017 | FXDWG |
| 2007-2017 | FXST |
