Harley Rear Axle Spacer Stepped - Ultima 33-26 - Big Twin 0+
by Ultima
SKU 44-3326
Axle spacer kit for the rear wheel, setting correct hub spacing and including the washers and nut needed for a clean install. Universal fit for most Harley axle applications.
Ultima #: 33-26
Steeped rear axle spacer is stepped for the caliper bracket as a replacement on Ultima Wide Drive Frames.
