Harley Sportster Rear Axle Zinc Plated - V-Twin 44-0089 - OEM 41563-77 - Ironhead 1977-1978
Zinc rear axle, a direct OEM-spec replacement for a worn, bent, or rusted stock axle that keeps the wheel running true. Fits 1977-1978 Harley Sportster models.
OEM #: 41563-77
Axle with hex head and threaded on both ends has a 12-5/8 inch bearing surface length and can be used to replace a worn out or damaged axle.
*NOTE: For 11/16 inch axle diameter.
- Bearing Surface: 12-5/8 inches
- Surface w/o Thread: 10-1/4 inches
- Overall Length: 14 inches
- Outer Diameter: 3/4 inches
- Threads per Inch: 18
- Inner Diameter: 11/16 inches
- Axle Diameter: 11/16 inches
| 1977-1978 | XLCR |
