Harley Big Twin Front Axle Zinc Plated - V-Twin 44-0224 - OEM 43875-48
Zinc front axle, a direct OEM-spec replacement for a worn, bent, or rusted stock axle that keeps the wheel running true. Fits 1948-1966 Harley Panhead and Shovelhead models.
OEM #: 43875-48
Triple stepped axle with threaded end has a 8-7/8 inch bearing surface length and can be used to replace a worn out or damaged axle.
- Bearing Surface: 8-7/8 inches
- Surface w/o Thread: 4-1/4 inches
- Overall Length:
- Outer Diameter: 5/8 inches
- Threads per Inch: 20
| 1948-1966 | FL |
