Harley Big Twin & Sportster Front Axle Zinc Plated - V-Twin 44-0204 - OEM 43871-52 - Sportster 1952-1972
Zinc front axle, a direct OEM-spec replacement for a worn, bent, or rusted stock axle that keeps the wheel running true. Fits 1952-1972 Harley K Model, Sportster, and Shovelhead models.
OEM #: 43871-52
Axle with threaded end has a 6 inch bearing surface length and and can be used to replace a worn out or damaged axle.
Order nut kit separately.
- Bearing Surface: 6 inches
- Surface w/o Thread: 5 inches
- Overall Length: 7-3/16 inches
- Outer Diameter: 5/8 inches
- Threads per Inch: 18
| 1971-1972 | FX |
| 1952-1956 | K |
| 1957-1972 | XL |
