Chrome Front Axle - V-Twin 44-0793 - OEM 41547-07A - Big Twin 2007-2023
SKU 44-0793
OEM #: 41547-07A
Axle with threaded end has a 10-3/4 inch bearing surface length and can be used to replace a worn out or damaged axle.
Order hardware separately. Will require 25mm ID bearings.
- Bearing Surface: 10-3/4 inches
- Surface w/o Thread: 8-1/8 inches
- Overall Length: 12-15/16 inches
- Outer Diameter: 25mm
- Threads per Inch: 18
| 2008-2023 | FLT |
| 2008-2017 | FXDF |
| 2008-2017 | FXDWG |
| 2007-2017 | FXST |
