Rear Rigid Axle Adjuster Kit - V-Twin 44-0575
SKU 44-0575
$59.99 - $59.99
Rigid axle adjuster kit is for use with a 3/4 inch axle on rigid or hardtail frames with 7/8 inch slots.
Includes black 2 - 3/4 inch x 24 x 3 adjusters and machined chrome axle blocks. Adjuster blocks go on the outside of the frame axle plates to use adjusters in existing threaded bosses. *NOTE: Requires at least a 12 inch bearing surface x 3/4 inch axle.
  • Adjuster O.D.: 1.472 inches
  • Adjuster Thickness: 3/8 inches
1941-1957 FL
