Harley Big Sucker Air Cleaner Kit Stage I - Arlen Ness 18-440 - Twin Cam Touring 2014-2016
Air cleaner kit that bundles the cover, backing plate, and mounting hardware together for one straightforward install instead of sourcing each piece separately. Fits 2014-2016 Harley Touring models.
Arlen Ness #: 18-440
Stage I air filter kit is for fuel injected models. For use with stock type covers.
The all in one backing plate features a built in carburetor support and built in breather tunnels at each head to decrease crankcase pressure. Each tunnel exits at the mouth of the carburetor to create a virtually closed loop system. Includes inchBig Sucker inch aluminum backing plate high-flow air filter 4 chrome banjo bolts simple instructions an all the necessary hardware. Bolt location center to center on Big Twin models is 15cm.
| 2014-2016 | FLT |
