{"product_id":"york-electric-start-oil-tank-chrome-v-twin-40-0491","title":"York Electric Start Oil Tank Chrome - V-Twin 40-0491","description":"\u003cp\u003eThis wrap around four quart center fill oil tank is for installation in rigid frames (stock replica or custom) with 4 speed transmissions with the York electric start kits. Tank includes a screw in dip stick cap.\u003c\/p\u003e\n\u003cp\u003eClamps for battery must be fabricated. The battery will require spacing to secure in place by the builder. *NOTE: Batteries must be ordered separately. Electric start uses Anti Gravity 12 Volt 16 Cell Battery. *NOTE: Requires an oil tank base for installation on York electric starter kits. Mount plate allows extra space for electric starters. The plate allows for mounting on 1936 models. *NOTE: Oil tank will fit 1941-1957 FL rigid frames when an electric start system is installed. Tank accepts standard drain plug and is the center top fill type.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Chrome Oil Tank Rear Fender Mount Bracket for rigid applications.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Anti Gravity 12 Volt 16 Cell Battery.\u003c\/li\u003e\n\u003cli\u003eRequired to use with Oil Tank Base Black.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with York Electric Starter Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with York Electric Starter Kit.\u003c\/li\u003e\n\u003cli\u003e*NOTE: Tank has a left side chain guard tab and may have to be removed on some installations.\u003c\/li\u003e\n\u003cli\u003e*NOTE: Tank body is full height. The rear bracket is raised up to accept base plate to allow clearance for the York electric starter.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1936-1952\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1957\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"York","offers":[{"title":"Default Title","offer_id":67553019756702,"sku":"40-0491","price":249.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/40-0491-york-electric-start-oil-tank-chrome-1.jpg?v=1792133655","url":"https:\/\/chopcult.com\/products\/york-electric-start-oil-tank-chrome-v-twin-40-0491","provider":"ChopCult","version":"1.0","type":"link"}
