{"product_id":"york-compensator-lock-nut-kit-v-twin-19-0487-twin-cam-2009-2013","title":"York Compensator Lock Nut Kit - V-Twin 19-0487 - Twin Cam 2009-2013","description":"\u003cp\u003eYork compensator lock nut kit includes a lock plate and lock tabs which secure the nut to the sprocket retainer so that the compensator nut and lock plate bolts does not come loose.\u003c\/p\u003e\n\u003cp\u003eSimilar to the bulletproof transmission pulley mega nut this lock kit is so that the compensator nut will not come loose and cause unnecessary unsafe and expensive damage. Kit includes 5 pieces; one long hex nut one lock tab washer one lock ring and two hex screws. *NOTE: For use with 34 Tooth Compensaotr Sprocket Kits only.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to only use with Compensator Sprocket Kit 34 Tooth.\u003c\/li\u003e\n\u003cli\u003eSuggested to only use with Compensator Sprocket Kit 34 Tooth.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e2009-2013\u003c\/td\u003e\n\u003ctd\u003eFLHXX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2012-2013\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2011-2013\u003c\/td\u003e\n\u003ctd\u003eFLT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2012-2013\u003c\/td\u003e\n\u003ctd\u003eFXD\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2012-2013\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/19\/19-0487.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"York","offers":[{"title":"Default Title","offer_id":67550893637790,"sku":"19-0487","price":69.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/19-0487-york-compensator-lock-nut-kit-twin-cam-2009-2013-1.jpg?v=1792110135","url":"https:\/\/chopcult.com\/products\/york-compensator-lock-nut-kit-v-twin-19-0487-twin-cam-2009-2013","provider":"ChopCult","version":"1.0","type":"link"}
