{"product_id":"weld-on-frame-hardtail-v-twin-51-0982-ironhead-1979-1981","title":"Weld-On Frame Hardtail - V-Twin 51-0982 - Ironhead 1979-1981","description":"\u003cp\u003eWeld on hardtail with weld on bracket for stock frames with 2000-UP disc brake.\u003c\/p\u003e\n\u003cp\u003eThe adjuster block are on the outside of the rear axle plate and are threaded to accept the axle adjuster kit. This hardtail accepts 3\/4 inch axle. Top seat plate is included but must be welded on by customer or fabricator. DIY hardtail is easy to install as the alignment is accomplished by the mount design provided. Custom application on 1979-1981 XL. Order battery carrier rear belt axle 2000-up caliper caliper mount exhaust bracket and hardware separately. Welding should be performed by a skilled welding technician. The axle's width ranges from 11-1\/4 inch - 11-3\/4 inch. Installer may spread or compress to necessary width. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTubing Diameter: 1.023 inches\u003c\/li\u003e\n\u003cli\u003eThickness Of Tubing: 0.182 inches\u003c\/li\u003e\n\u003cli\u003eWidth Between Axle: 10-3\/4 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eDue to the welding process this may vary slightly and builder will need to modify accordingly.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Chrome Battery Carrier Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Chrome Battery Carrier Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Replica Chrome Rear Calilper with Bracket and Brake Pads.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with 16inch Rear Spoke Wheel.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Raw Rear Axle.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1979-1981\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67554193604766,"sku":"51-0982","price":389.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/51-0982-weld-on-frame-hardtail-ironhead-1979-1981-1.jpg?v=1792141133","url":"https:\/\/chopcult.com\/products\/weld-on-frame-hardtail-v-twin-51-0982-ironhead-1979-1981","provider":"ChopCult","version":"1.0","type":"link"}
