{"product_id":"weld-on-frame-hardtail-v-twin-51-0920","title":"Weld-On Frame Hardtail - V-Twin 51-0920","description":"\u003cp\u003eWeld on hardtail fits stock frames is drum brake style and accepts chain drive.\u003c\/p\u003e\n\u003cp\u003eDIY hardtailing is easy to install as the alignment is accomplished in the mount design provided. Welding should be performed by a skilled welding technician. Weld on unit should be aligned for chain clearance prior to final welding. The distance between the inside to inside of the axle plates is 9-1\/8 inch. The axle slots are 7\/8 inch on both sides. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eThe width of the tail section should be exactly 9-1\/8inch. Due to the welding process this may vary slightly \u0026amp; builder will need to modify accordingly.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67554189934750,"sku":"51-0920","price":339.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/51-0920-weld-on-frame-hardtail-1.jpg?v=1792141115","url":"https:\/\/chopcult.com\/products\/weld-on-frame-hardtail-v-twin-51-0920","provider":"ChopCult","version":"1.0","type":"link"}
