{"product_id":"v-fire-single-fire-electronic-ignition-distributor-v-twin-32-0072","title":"Harley Big Twin V-Fire Single Fire Electronic Ignition Distributor - V-Twin 32-0072","description":"\u003cp\u003eV-Fire completed electronic distributor assembly includes distributor body and shaft with reverse tooth gear single fire electronic ignition unit sensor cup wire and hold down clamp. Distributor top can be removed without removing front head. Distributor uses cone style ignitions from 1970-up applications. Includes single fire ignition module where each cylinder fires independently for all the Big Twin applications. Distributor is designed for a late model electric ignition and uses a reverse drive gear the drive gear used must be a inchreverse rotation inch gear and is avaibale separately. NOTE: Single fire indicators spark for each individual cylinder one at a time. *NOTE: Distributor includes internals that require reverse rotation gears! Installation instructions (PDF). Fits 1936-1969 Harley Knucklehead, Panhead, and Shovelhead models.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eRequired to use with Distributor Mount Clamp Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Chrome Distributor Cover.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Circuit Breaker Gear.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1936-1952\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1969\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67551687704734,"sku":"32-0072","price":349.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-0072-v-fire-single-fire-electronic-ignition-distributor-1.jpg?v=1792121720","url":"https:\/\/chopcult.com\/products\/v-fire-single-fire-electronic-ignition-distributor-v-twin-32-0072","provider":"ChopCult","version":"1.0","type":"link"}
