{"product_id":"v-fire-overhead-valve-auto-advance-distributor-chrome-v-twin-32-1890","title":"Harley Big Twin V-Fire Overhead Valve Auto Advance Distributor Chrome - V-Twin 32-1890","description":"\u003cp\u003eV-Fire auto advance distributor features a chrome body and top. Distributor is completely assembled with gear and all internal parts and features a two bolt flange. This is single point type with updated timing marks. For Overhead Valve Big Twin models. Point lead wire not included. Distributor has an auto advance and can be used to upgrade your old system or for use on your ground-up build. No need for the left hand spark advance control use a snap throttle on any handlebar. Front cylinder head must be removed for installation. Replacement for ignition advance rotor and points plate assembly available seperately. Distributor wire lead available separately. Order mount screw sets separatley. *NOTE: Points lead wire should exit thru the inchV inch slot in the base which should face the rear of the motorcycle. Updated points plate allows wire to exit toward rear. *NOTE: Drilling a hole in the plate helps to set advance when timing. *NOTE: We recommend updating the points set. Advance points plate available separately. This plate allows point to exit from rear of distributor. Fits 1936-1965 Harley Knucklehead and Panhead models.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\n\u003cul\u003e\n\u003cli\u003eSuggested to use with Ignition Advance with Points Plate Assembly.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Chrome Distributor Cover.\u003c\/li\u003e\n\u003cli\u003ePoints go on the front side for ease of adjusting. Both lobes should open \u0026amp; close points but the skinny lobe times the front cylinder see service manual.\u003c\/li\u003e\n\u003cli\u003eThere is no mark on the cam. Must time at cylinder top dead center. Unit requires removal of front head for installation.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with #8145-10 Chrome Circuit Breaker Screws\u003c\/li\u003e\n\u003cli\u003eSuggested to use with #8146-10 Cadmium Circuit Breaker Screws\u003c\/li\u003e\n\u003cli\u003eSuggested to use with #9684-10 Parkerized Distributor Screws\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Distributor Lead Wire.\u003c\/li\u003e\n\u003cli\u003eRecommended to use with Blue Streak Ignition Point Set.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1936-1940\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1941-1965\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67551810715806,"sku":"32-1890","price":249.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-1890-v-fire-overhead-valve-auto-advance-distributor-chrome-1.jpg?v=1792123210","url":"https:\/\/chopcult.com\/products\/v-fire-overhead-valve-auto-advance-distributor-chrome-v-twin-32-1890","provider":"ChopCult","version":"1.0","type":"link"}
