{"product_id":"universal-black-8mm-spark-plug-kit-volt-tech-40151","title":"Harley Universal Black 8mm Spark Plug Kit - Volt Tech 40151","description":"\u003cp\u003eUniversal spark plug suppression wire kit includes two 24 inch wire leads with 90° molded plug boots and straight coil boots with brass terminals. Wire has a silicone casing with inner suppression wire. Wire set works with points style ignition. Coil terminal ends are made of stainless steel and must be attached after wire is cut to required length. **NOTE: if using an aftermarket ignition please check with the manufacturers OHM requirement. *NOTE: Not for use on 1999-up Big Twin and 2007-up XL models. Universal fit for most Harley applications.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eVolt Tech #:\u003c\/strong\u003e 40151\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\n\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Volt Tech","offers":[{"title":"Default Title","offer_id":67551781781662,"sku":"32-1042","price":14.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-1042-universal-black-8mm-spark-plug-kit-volt-tech-40151-1.jpg?v=1792122364","url":"https:\/\/chopcult.com\/products\/universal-black-8mm-spark-plug-kit-volt-tech-40151","provider":"ChopCult","version":"1.0","type":"link"}
