{"product_id":"ul-bobbed-gas-tank-kit-v-twin-38-1885","title":"UL Bobbed Gas Tank Kit - V-Twin 38-1885","description":"\u003cp\u003eBobbed gas tank kit includes a two piece gas tank set with a 3.5 gallon fuel capacity. Includes a replica gas cap set shutoff rod kit mount bolt kit shifter lever shifter gate and shifter gate screw. For UL-ULH Flatheads.\u003c\/p\u003e\n\u003cp\u003eIncludes painted emblems and four stainless steel emblem trim strips. Tank set accepts a cateye dash only. The lower bracket is inchC inch shaped. Tank may require fuel rod alignment before installation of shut off assembly. Check the tank for flaws or fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check shut off opening making sure the shut off valve can be easily installed. Shut off fitting should be masked or plugged during painting for easy installation of the shut off valve. Will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve the correct height. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1940-1946\u003c\/td\u003e\n\u003ctd\u003eUL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552863125662,"sku":"38-1885","price":689.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-1885-ul-bobbed-gas-tank-kit-1.jpg?v=1792132556","url":"https:\/\/chopcult.com\/products\/ul-bobbed-gas-tank-kit-v-twin-38-1885","provider":"ChopCult","version":"1.0","type":"link"}
