{"product_id":"tapered-bearing-wheel-hub-star-type-chrome-v-twin-45-0806","title":"Tapered Bearing Wheel Hub Star Type Chrome - V-Twin 45-0806","description":"\u003cp\u003eTapered front or rear star type bearing wheel hub features a chrome finish.\u003c\/p\u003e\n\u003cp\u003eHub will not accept stock OE type axles. Installation will require axle sleeve and spacers to be modified or fabricated by installer. Hub features a 11\/16 inch I.D. tapered bearing. And requires the use of an 11\/16 inch (0.6875) axle. VT and are 11\/16 inch O.D. but will still require axle to be cut to correct length based on application. Axle lengths are noted in web description for each part number. If required order sleeve for 1941-1957 rigid models. *NOTE: OEM axles must be turned down to install!. Start hub with sealed ball bearing accepts 11\/16 inch axle for use as a spool wheel hub.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eInner Diameter: 11\/16 inches\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Chrome Rear Axle.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Replica Rear Axle Zinc Plated.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with XL Chrome Rear Axle.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with XL Rear Axle Zinc Plated.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Rear Axle Zinc Plated.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1936-1966\u003c\/td\u003e\n\u003ctd\u003eEL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67553366737054,"sku":"45-0806","price":319.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/45-0806-tapered-bearing-wheel-hub-star-type-chrome-1.jpg?v=1792136697","url":"https:\/\/chopcult.com\/products\/tapered-bearing-wheel-hub-star-type-chrome-v-twin-45-0806","provider":"ChopCult","version":"1.0","type":"link"}
