{"product_id":"stretch-chopper-3-8-gallon-gas-tank-v-twin-38-0279","title":"Stretch Chopper 3.8 Gallon Gas Tank - V-Twin 38-0279","description":"\u003cp\u003eNew Old Stock inch Gas tank has a left side petcock opening and a fuel capacity of 3.8 gallons. It features ISO mount straps and a curved underside with recessed mount holes.\u003c\/p\u003e\n\u003cp\u003eCenter to center measurement of mounting holes are 13-1\/4 inch. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check the petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. *NOTE: Over 20 years old stock some rust and small dings on surface. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 27.5 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 24.5 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 2.5 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 12 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 10-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 6-7\/8 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 24-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Width: 2-3\/8 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Smooth Style Gas Cap Vented.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Petcock Wing Type Chrome.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552817184926,"sku":"38-0279","price":409.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0279-stretch-chopper-3-8-gallon-gas-tank-1.jpg?v=1792132020","url":"https:\/\/chopcult.com\/products\/stretch-chopper-3-8-gallon-gas-tank-v-twin-38-0279","provider":"ChopCult","version":"1.0","type":"link"}
