{"product_id":"stretch-chopper-3-0-gallon-gas-tank-v-twin-38-0272","title":"Stretch Chopper 3.0 Gallon Gas Tank - V-Twin 38-0272","description":"\u003cp\u003eGas tank accepts a left side 3\/8 inch National Pipe Thread petcock and has a fuel capacity of 3.0 gallons. It features a curved underside and dual strap mount kit with bushings.\u003c\/p\u003e\n\u003cp\u003eCheck the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 23 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 19 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 3 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 9 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 1 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 9 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 4-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 7\/8 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 22-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eTunner Width: 2-3\/8 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Smooth Style Gas Cap Vented\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Kreem Gas Tank Combo Kit.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552817021086,"sku":"38-0272","price":239.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0272-stretch-chopper-3-0-gallon-gas-tank-1.jpg?v=1792132013","url":"https:\/\/chopcult.com\/products\/stretch-chopper-3-0-gallon-gas-tank-v-twin-38-0272","provider":"ChopCult","version":"1.0","type":"link"}
