{"product_id":"stock-replica-bobbed-5-1-gallon-gas-tank-wyatt-gatling-012910-oem-61625-08-twin-cam-softail-2008-2010","title":"Stock Replica Bobbed 5.1 Gallon Gas Tank - Wyatt Gatling 012910 - OEM 61625-08 - Twin Cam Softail 2008-2010","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 012910 · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 61625-08\u003c\/p\u003e\n\u003cp\u003eStock replica gas tank has a left side fuel line fitting and has a fuel capacity of 5.1 gallons. Tank uses stock mounting hardware.\u003c\/p\u003e\n\u003cp\u003eThis EFI type tank has provisions to fit an OE fuel gauge in left hand bung hole. The tank requires sanding and primer before painting. Fuel line fitting should be masked or plugged during painting for easy installation of fuel line. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18-1\/4 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 17-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 9 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 15-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 1 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 9 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 7 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 18 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with Kreem Gas Tank Combo Kit.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Gas Tank Fuel Gauge Block Off Kit.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e2008-2010\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e2008-2010\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552853557406,"sku":"38-0798","price":609.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0798-stock-replica-bobbed-5-1-gallon-gas-tank-wyatt-gatling-012910-oem-61625-08-twin-cam-softail-2008-2010-1.jpg?v=1792132356","url":"https:\/\/chopcult.com\/products\/stock-replica-bobbed-5-1-gallon-gas-tank-wyatt-gatling-012910-oem-61625-08-twin-cam-softail-2008-2010","provider":"ChopCult","version":"1.0","type":"link"}
