{"product_id":"stock-6-volt-replica-ignition-coil-1-5-ohms-black-volt-tech-72375b-oem-31604-48","title":"Stock 6 Volt Replica Ignition Coil 1.5 Ohms Black - Volt Tech 72375B - OEM 31604-48","description":"\u003cp\u003e\u003cstrong\u003eVolt Tech #:\u003c\/strong\u003e 72375B · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 31604-48, 1722-48A\u003c\/p\u003e\n\u003cp\u003eBlack steel jacketed 6 volt ignition coil features updated internal wiring and sealing with nuts packing and wires.\u003c\/p\u003e\n\u003cp\u003eFor use on single point distributors. *NOTE: Coil mounts directly to the studs on the frame. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. ***NOTE: Coils are factory tested before packaging. Full warranty thru the dealer where you purchased! Over 20 000 coils sold since 1990!\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1948-1960\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Volt Tech","offers":[{"title":"Default Title","offer_id":67551788794014,"sku":"32-1338","price":109.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-1338-stock-6-volt-replica-ignition-coil-1-5-ohms-black-volt-tech-72375b-oem-31604-48-1.jpg?v=1792122615","url":"https:\/\/chopcult.com\/products\/stock-6-volt-replica-ignition-coil-1-5-ohms-black-volt-tech-72375b-oem-31604-48","provider":"ChopCult","version":"1.0","type":"link"}
