{"product_id":"solid-state-6-volt-relay-with-black-cover-volt-tech-77378b","title":"Solid State 6 Volt Relay with Black Cover - Volt Tech 77378B","description":"\u003cp\u003e\u003cstrong\u003eVolt Tech #:\u003c\/strong\u003e 77378B\u003c\/p\u003e\n\u003cp\u003eSolid state relay is 6 volt three terminal style with a black cover with eliminator. It replaces original style mechanical relay for 6 volt 32-E style generators.\u003c\/p\u003e\n\u003cp\u003eSolid state relay eliminator is housed in a Delco style body and base. The unit will replace stock relay on 6 volt 32-E model applications and will retain original look. Unit does not allow for use of the charge indicating lamp on the dash. Mounts as original relay hardware is not included. Solid State relay is shipped loose with base and cover.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Solid Sate 6V Relay Eliminator.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e0\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/32\/32-0299.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Volt Tech","offers":[{"title":"Default Title","offer_id":67551701008542,"sku":"32-0299","price":64.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/32-0299-solid-state-6-volt-relay-with-black-cover-volt-tech-77378b-1.jpg?v=1792121864","url":"https:\/\/chopcult.com\/products\/solid-state-6-volt-relay-with-black-cover-volt-tech-77378b","provider":"ChopCult","version":"1.0","type":"link"}
