{"product_id":"side-valve-74-80-engine-gasket-kit-athena-p400195850983-oem-17027-36","title":"Side Valve 74\/80\" Engine Gasket Kit - Athena P400195850983 - OEM 17027-36","description":"\u003cp\u003e\u003cstrong\u003eAthena #:\u003c\/strong\u003e P400195850983 · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 17027-36\u003c\/p\u003e\n\u003cp\u003eSide Valve 74 inch\/80 inch engine gasket kit.\u003c\/p\u003e\n\u003cp\u003eIncludes blue teflon head gaskets cylinder base gaskets guide gaskets upper pushrod gaskets middle cork pushrod cover gaskets lower pushrod cover gaskets valve cover seals tappet cover seals crankcase relief gasket gear cover gasket oil feed pump gasket pump base and cover gaskets and distributor base gasket. *NOTE: Can order other copper head gaskets if preferred.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Replica Head Gasket Copper\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1936-1948\u003c\/td\u003e\n\u003ctd\u003eUL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Athena","offers":[{"title":"Default Title","offer_id":67549740925086,"sku":"15-0515","price":64.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/15-0515.jpg?v=1791658366","url":"https:\/\/chopcult.com\/products\/side-valve-74-80-engine-gasket-kit-athena-p400195850983-oem-17027-36","provider":"ChopCult","version":"1.0","type":"link"}
