{"product_id":"servi-car-raw-front-fender-v-twin-50-0739-oem-59007-50","title":"Servi-Car Raw Front Fender - V-Twin 50-0739 - OEM 59007-50","description":"\u003cp\u003e\u003cstrong\u003eOEM #:\u003c\/strong\u003e 59007-50\u003c\/p\u003e\n\u003cp\u003eRaw front fender is a glide style fender with wide Spring Fork braces to fit servi-cars with an offset rocker Spring Fork and a star hub wheel. Axle plate mounts are 11-1\/2 inch wide between the inside surfaces.\u003c\/p\u003e\n\u003cp\u003eBrackets included with this fender are secured in place by rivets. Front fender tip trim holes must be drilled if needed. Before priming or painting fit the fender body braces and mounting points in place. Fender rivets hinge and brackets will have to be tweaked for final fitment. Patience is required for proper installation! *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eInner Width: 6-3\/4 inches\u003c\/li\u003e\n\u003cli\u003eOuter Width: 7 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use fender tip or side spears or fender kit.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1950-1957\u003c\/td\u003e\n\u003ctd\u003eG\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67553996210334,"sku":"50-0739","price":189.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/50-0739-servi-car-raw-front-fender-oem-59007-50-1.jpg?v=1792140021","url":"https:\/\/chopcult.com\/products\/servi-car-raw-front-fender-v-twin-50-0739-oem-59007-50","provider":"ChopCult","version":"1.0","type":"link"}
