{"product_id":"s-s-stock-bore-shovelhead-engine-crankcase-set-s-s-cycle-31-0003","title":"S\u0026S Stock Bore Shovelhead Engine Crankcase Set - S\u0026S Cycle 31-0003","description":"\u003cp\u003e\u003cstrong\u003eS\u0026amp;S Cycle #:\u003c\/strong\u003e 31-0003\u003c\/p\u003e\n\u003cp\u003eCrankcase set comes ready to assemble.\u003c\/p\u003e\n\u003cp\u003eS\u0026amp;S Crankcase Sets are shipped set-up with Timken left side bearing and race assembly seal and seal spacer oil pump drive bushing needle bearing and pinion race for right side is pressed in and line honed ready to assemble. Also included are cylinder studs nickel plated case bolts crankcase fittings and a timing and magnetic drain plug. Engine case features stock bore and accepts flywheels up to 8-1\/2 inch diameter. Manufacturer's Statement of Origin is supplied.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Oil Pump Assembly.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1970-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1979-1984\u003c\/td\u003e\n\u003ctd\u003eFLT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1971-1984\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1982-1984\u003c\/td\u003e\n\u003ctd\u003eFXR\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"S\u0026S Cycle","offers":[{"title":"Default Title","offer_id":67546560987294,"sku":"10-0003","price":1629.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/10-0003a.jpg?v=1791604465","url":"https:\/\/chopcult.com\/products\/s-s-stock-bore-shovelhead-engine-crankcase-set-s-s-cycle-31-0003","provider":"ChopCult","version":"1.0","type":"link"}
