{"product_id":"s-s-stock-bore-engine-crankcase-set-s-s-cycle-31-0010","title":"S\u0026S Stock Bore Engine Crankcase Set - S\u0026S Cycle 31-0010","description":"\u003cp\u003e\u003cstrong\u003eS\u0026amp;S Cycle #:\u003c\/strong\u003e 31-0010\u003c\/p\u003e\n\u003cp\u003eCrankcase set for 1965-1969 Big Twin Shovelhead engine comes ready to assemble.\u003c\/p\u003e\n\u003cp\u003eS\u0026amp;S crankcase sets are shipped set up with Timken left side bearing and race assembly seal and seal spacer oil pump drive bushing needle bearing and pinion race for right side is pressed in and line honed ready to assemble. Also included are cylinder studs nickel plated case bolts crankcase fittings and a timing \u0026amp; magnetic drain plug. Engine crankcase has stock bore and accepts flywheels up to 8½ inch diameter. Manufacturer's Statement of Origin is supplied.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eOrder oil pump required for assembly\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1966-1969\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"S\u0026S Cycle","offers":[{"title":"Default Title","offer_id":67546562461854,"sku":"10-0030","price":1879.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/10-0030a.jpg?v=1791604480","url":"https:\/\/chopcult.com\/products\/s-s-stock-bore-engine-crankcase-set-s-s-cycle-31-0010","provider":"ChopCult","version":"1.0","type":"link"}
