{"product_id":"s-s-steel-cam-chest-breather-valve-standard-s-s-cycle-33-4241-oem-25313-77a-big-twin-1979-1998","title":"S\u0026S Steel Cam Chest Breather Valve Standard - S\u0026S Cycle 33-4241 - OEM 25313-77A - Big Twin 1979-1998","description":"\u003cp\u003e\u003cstrong\u003eS\u0026amp;S Cycle #:\u003c\/strong\u003e 33-4241 · \u003cstrong\u003eOEM #:\u003c\/strong\u003e 25313-77A\u003c\/p\u003e\n\u003cp\u003eS\u0026amp;S steel cam chest breather valve is a machined breather valve and gear. Designed to replace stock steel or plastic units.\u003c\/p\u003e\n\u003cp\u003eFeatures stock duration with standard 1.121 inch outer diameter groove cut along bottom and inchT inch shaped timing mark on gear. Order 8 piece thrust washer set separately.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eSuggested to use with S\u0026amp;S Breather Cam Chest Washer Set.\u003c\/li\u003e\n\u003cli\u003eSuggested to use with Cam Chest Breather Valve Washer Set.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1979-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1986-1998\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1979-1998\u003c\/td\u003e\n\u003ctd\u003eFLT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1979-1984\u003c\/td\u003e\n\u003ctd\u003eFX\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1991-1998\u003c\/td\u003e\n\u003ctd\u003eFXD\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1982-1994\u003c\/td\u003e\n\u003ctd\u003eFXR\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1984-1998\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"S\u0026S Cycle","offers":[{"title":"Default Title","offer_id":67549530849438,"sku":"12-9906","price":129.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/12-9906.jpg?v=1791654887","url":"https:\/\/chopcult.com\/products\/s-s-steel-cam-chest-breather-valve-standard-s-s-cycle-33-4241-oem-25313-77a-big-twin-1979-1998","provider":"ChopCult","version":"1.0","type":"link"}
