{"product_id":"s-s-engine-crankcase-set-stock-bore-s-s-cycle-31-0000-evolution-1984-1991","title":"S\u0026S Engine Crankcase Set Stock Bore - S\u0026S Cycle 31-0000 - Evolution 1984-1991","description":"\u003cp\u003eNatural crankcase set for 1984-1991 Big Twin V2 type engine comes ready to assemble.\u003c\/p\u003e\n\u003cp\u003eS\u0026amp;S crankcase set includes Timken left side bearing race assembly seal seal spacer oil pump drive bushing needle bearing pinion race for right side is pressed in and line honed ready to assemble. Also included are cylinder studs nickel plated case bolts crankcase fittings a timing and magnetic drain plug. Case features stock bore and will accept flywheels up to 8-1\/2 inch diameter. Manufacturer's Statement of Origin is supplied.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eS\u0026amp;S Cycle part #:\u003c\/strong\u003e 31-0000\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Oil Pump Assembly.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1986-1991\u003c\/td\u003e\n\u003ctd\u003eFLST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1984-1991\u003c\/td\u003e\n\u003ctd\u003eFLT\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1984-1991\u003c\/td\u003e\n\u003ctd\u003eFXR\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1984-1991\u003c\/td\u003e\n\u003ctd\u003eFXST\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"S\u0026S Cycle","offers":[{"title":"Default Title","offer_id":67546391347358,"sku":"10-0000","price":1629.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/10-0000a.jpg?v=1791596856","url":"https:\/\/chopcult.com\/products\/s-s-engine-crankcase-set-stock-bore-s-s-cycle-31-0000-evolution-1984-1991","provider":"ChopCult","version":"1.0","type":"link"}
