{"product_id":"rigid-frame-forging-hallmark-plate-v-twin-51-0068","title":"Harley Rigid Frame Forging Hallmark Plate - V-Twin 51-0068","description":"\u003cp\u003eRaw steel frame forging hallmark plate is an accurate investment for reconstruction and restoration of 1936-1957 rigid frames includes various forging logos and numbers. Investment cast steel in one sheet cut numbers out as desired. Frame may be milled or ground down to accept numbers and forging marks. The numbers when cut from the plate may be ground down for specific application. *NOTE: Must be welded in place. *NOTE: The plate is 2.5 - 2.8mm thick. Installation instructions (PDF). Universal fit for most Harley frame applications.\u003c\/p\u003e\n\u003cp\u003eRaw steel frame forging hallmark plate is an accurate investment for reconstruction and restoration of 1936-1957 rigid frames includes various forging logos and numbers.\u003c\/p\u003e\n\u003cp\u003eInvestment cast steel in one sheet cut numbers out as desired. Frame may be milled or ground down to accept numbers and forging marks. The numbers when cut from the plate may be ground down for specific application. *NOTE: Must be welded in place. *NOTE: The plate is 2.5 - 2.8mm thick.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1936-1957\u003c\/td\u003e\n\u003ctd\u003eCustom\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/51\/51-0068.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67554080784542,"sku":"51-0068","price":119.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/51-0068-rigid-frame-forging-hallmark-plate-1.jpg?v=1792140767","url":"https:\/\/chopcult.com\/products\/rigid-frame-forging-hallmark-plate-v-twin-51-0068","provider":"ChopCult","version":"1.0","type":"link"}
