{"product_id":"replica-xl-2-4-gallon-gas-tank-wyatt-gatling-63037-evolution-sportster-1993-2003","title":"Replica XL 2.4 Gallon Gas Tank - Wyatt Gatling 63037 - Evolution Sportster 1993-2003","description":"\u003cp\u003e\u003cstrong\u003eWyatt Gatling #:\u003c\/strong\u003e 63037\u003c\/p\u003e\n\u003cp\u003eReplica gas tank has a left side petcock location and a fuel capacity of 2.4 gallons.\u003c\/p\u003e\n\u003cp\u003eHigh tunnel stock style tank features stock mounts and filler neck. It uses a 1975-up petcock with external thread for nut. *NOTE: Must order hardware separately. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help to stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of the petcock. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eMeasurements:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eTop Length: 18 inches\u003c\/li\u003e\n\u003cli\u003eBottom Length: 13 inches\u003c\/li\u003e\n\u003cli\u003eRear Width: 4 inches\u003c\/li\u003e\n\u003cli\u003eFront Width: 8 inches\u003c\/li\u003e\n\u003cli\u003eRear Height: 4-1\/2 inches\u003c\/li\u003e\n\u003cli\u003eFront Height: 8 inches\u003c\/li\u003e\n\u003cli\u003eFront Tunnel Height: 4 inches\u003c\/li\u003e\n\u003cli\u003eRear Tunnel Height: 1\/2 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Length: 17 inches\u003c\/li\u003e\n\u003cli\u003eTunnel Width: 2 inches\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eSuggested to use with Gas Tank Mounting Kit.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1993-2003\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e\n\u003cp\u003e\u003ca href=\"http:\/\/www.vtwinmfg.com\/Instructions\/MS\/gastanks.pdf\" target=\"_blank\" rel=\"noopener\"\u003eInstallation instructions (PDF)\u003c\/a\u003e\u003c\/p\u003e","brand":"Wyatt Gatling","offers":[{"title":"Default Title","offer_id":67552808534174,"sku":"38-0039","price":219.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0039-replica-xl-2-4-gallon-gas-tank-wyatt-gatling-63037-evolution-sportster-1993-2003-1.jpg?v=1792131915","url":"https:\/\/chopcult.com\/products\/replica-xl-2-4-gallon-gas-tank-wyatt-gatling-63037-evolution-sportster-1993-2003","provider":"ChopCult","version":"1.0","type":"link"}
