{"product_id":"replica-swingarm-frame-v-twin-51-1006","title":"Replica Swingarm Frame - V-Twin 51-1006","description":"\u003cp\u003eReplica swingarm frame is our authentic reproduction of FLH style to accept a Panhead or Shovelhead engine 4-speed transmission seat post and accepts a round or square swingarm. All components are pressed and formed as stock.\u003c\/p\u003e\n\u003cp\u003eFrame details include forged parts as original in neck motor mounts front transmission mount plate top seat post yoke strut swingarm pivot mount and footboard mounts as required. Accepts a 12-volt electric start battery box. Fork neck without key lock has blank number boss on right side and will accept lock assembly. Frame will accept round 1958-1972 drum brake or square 1973-1985 swingarm. Order shock studs separately recommend using 12 or 13-1\/2 inch shocks. Frame includes swingarm pin and oil tank bracket. Rear drum brake models use 13-1\/2 inch shocks and rear disc brake models use 12 inch shocks. *NOTE: There are no serial numbers stamped on the replica frame. V-Twin MFG supplys a Bill of Sale only. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs. **NOTE: Seat post may require further reaming for proper fit. For this reason frames will not be accepted for return (RGA)\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003e*NOTE: The size of the blank number pad on the right side of the neck measures 3\/4inch x 3inch.\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\n\u003ctr\u003e\n\u003ctd\u003e1965-1984\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003ctr\u003e\n\u003ctd\u003e1965-1984\u003c\/td\u003e\n\u003ctd\u003eFLH\u003c\/td\u003e\n\u003c\/tr\u003e\n\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67554195079326,"sku":"51-1006","price":1569.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/51-1006-replica-swingarm-frame-1.jpg?v=1792141155","url":"https:\/\/chopcult.com\/products\/replica-swingarm-frame-v-twin-51-1006","provider":"ChopCult","version":"1.0","type":"link"}
