{"product_id":"replica-straight-leg-rigid-frame-v-twin-51-1956","title":"Replica Straight Leg Rigid Frame - V-Twin 51-1956","description":"\u003cp\u003eReplica straight leg rigid frame is for chain drive models.\u003c\/p\u003e\n\u003cp\u003eThis frame is an authentic reproduction of the 1954-1957 straight leg frame with a stock 30° neck rake. Forged parts include: neck front and rear engine mount side car mounts top seat yoke axle seat post and footboard tabs. Front engine mount spacer will allow installation of a Knucklehead or Flathead engine. Cross shaft may be removed for use with hydraulic or disc brakes. Disc or drum brake tabs are available separately. Seat post bushing seat post assembly brake cross shaft and mechanical brake cross tube bushing may require reaming prior to assembly for proper fit. Therefore frame will not be accepted for return (RGA). The frame has an indent on the left lower rear frame bar from tooling fixture. V-Twin MFG supplys a Bill of Sale only referencing the part number. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\n\u003cli\u003eUse Front Engine Mount Spacer to accept 1936-1947 Knucklehead or Flathead engines in 1948-up frames.\u003c\/li\u003e\n\u003cli\u003eFeatures Replica Tool Box Mounting Bracket.\u003c\/li\u003e\n\u003cli\u003eIncludes:\u003c\/li\u003e\n\u003cli\u003e°Seat Post\u003c\/li\u003e\n\u003cli\u003e°Transmission Mount Plate\u003c\/li\u003e\n\u003cli\u003e°Rear Axle\u003c\/li\u003e\n\u003cli\u003e°Brake Cross Shaft\u003c\/li\u003e\n\u003cli\u003eSuggested to use tab for Disc Brake or tab for Drum Brake.\u003c\/li\u003e\n\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e1954-1957\u003c\/td\u003e\n\u003ctd\u003eFL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67554210775198,"sku":"51-1956","price":2099.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/51-1956-replica-straight-leg-rigid-frame-1.jpg?v=1792141251","url":"https:\/\/chopcult.com\/products\/replica-straight-leg-rigid-frame-v-twin-51-1956","provider":"ChopCult","version":"1.0","type":"link"}
