{"product_id":"replica-king-3-2-gallon-gas-tank-v-twin-38-0742-sportster-2007","title":"Replica King 3.2 Gallon Gas Tank - V-Twin 38-0742 - Sportster 2007+","description":"\u003cp\u003eGas tank is a replica of the 1996-up stock versions and has a left side petcock location and a fuel capacity of 3.2 gallons. Gas tank is zinc plated inside and out.\u003c\/p\u003e\n\u003cp\u003eTank features an updated design shape that rolls the bottom edge under to give flowing lines while still retaining the classic shape. Please test fitment before painting. Tank weld seams may require filler to meet your individual requirements. Do not grind or sand the seams or joints as this may cause leaks. We suggest using Kreem gas tank combo kit to clean condition and seal. This will help to stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of petcock. Requires the use of V-Twin petcock adapter fitting available for purchase separately. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003eNotes:\u003c\/strong\u003e\u003c\/p\u003e\u003cul\u003e\u003cli\u003eRequired to use with Petcock Adapter Fitting\u003c\/li\u003e\u003c\/ul\u003e\n\u003cp\u003e\u003cstrong\u003eFitment:\u003c\/strong\u003e\u003c\/p\u003e\u003ctable\u003e\u003ctbody\u003e\u003ctr\u003e\n\u003ctd\u003e2007-UP\u003c\/td\u003e\n\u003ctd\u003eXL\u003c\/td\u003e\n\u003c\/tr\u003e\u003c\/tbody\u003e\u003c\/table\u003e","brand":"V-Twin Manufacturing","offers":[{"title":"Default Title","offer_id":67552851886238,"sku":"38-0742","price":189.99,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/1692\/2127\/files\/38-0742-replica-king-3-2-gallon-gas-tank-sportster-2007-1.jpg?v=1792132318","url":"https:\/\/chopcult.com\/products\/replica-king-3-2-gallon-gas-tank-v-twin-38-0742-sportster-2007","provider":"ChopCult","version":"1.0","type":"link"}
